Please Help!
Im changing the clutch on my car. The drive shafts are out. I`ve removed the necessary engine mounts and the prop shaft. I`ve also removed all the bolts from the bell housing, including the sod next to the starter motor. But It still wont come apart :? Do I have to take the transfer box off? If so, does it share oil with the gear box and wot oil should i fill it with and how much :?:
Cheers Dan.
Olly
Can leave prop on, have you removed the front diff/shaft? Have you removed the Speed sensor and the BOLT (the one that gets left out by some garages Have you removed all the transfer box bolts 14mm (presuming your leaving it on) and just taking the box out.
Good fun init 8)
Do you have to take the bolts out of the transfer box even if its staying on :?: What should I be left with, still attached to the engine :?: Its driving me mad :evil:
