Non start!
andy_tt
Went to start my car yesterday and it fired and cut out straight away, now its making no attempt to fire. Ive done a fault code read and theres no codes. Had the plugs out and there bone dry so looks like no fuel. Put some fuel in the bores and it fired and cut out so im certain its a fuelling issue. Ive checked the wiring from injectors to ecu, have volts at the injectors and ecu but there not firing. Have checked the resistor pack and its just in spec. Had the dizzy of and turned the shaft and pump runs but cant hear injectors. Anyone had this before?? The car has been running fine till this
The Doc
Injector earths on plenum, clean and re terminate if not, main engine earth to chassis, clean and re terminate , pull fuel lines of fuel rail put in a can and see if the fuel is getting to fuel rail.
andy_tt
Fuel is getting to the rail. Looking at the diagram the ecu should switch the earths for the injectors. It looks like tgeres 2 triggers built into the dizzy, one is for spark and the other for fuel, the pump runs when u turn the dizzy shaft, so ecu must be getting its trigger signal. Could I be looking at a dodgy ecu?
