if you are running with std boost,just get it set up for normal unleaded.it will save you a bit on petrol and you`ll only lose 7 bhp,which you`ll never miss.gtirmouse said:i know ur only supposed to run shell optimax or bp ultimate, but can u run normal unleaded with octain booster? :?
Moved to regular maintenance - FAST GUY
any increase in boost usually means an increase in octane rating is required to make the same amount of power.you can increase the boost but would PROB have to retard the timing to run it on unleaded so negating the increase in boost.geetee said:Any reason you can't do this with increased boost?
I'd guess not as long as you get it properly setup to ensure no DET...
But then is it worth it??
DOH!!! :?gtirmouse said:thanks for the replys, sorry i didnt mean normal unleaded i meant normal super unleaded instead of optimax/ultimate cheers guys
lol oopsDOH!!!
thats my local Q8 as well jus - its elliot 8)My local Q8's super is 98RON
