Heres a bit of info I have been researching lately its all off the net so very easy to find/read but worthwhile looking into for all of us running higher boost etc and disconnecting various pipes ...
Check for loss of EGR. The Exhaust Gas Recirculation (EGR) system is one of the engine's primary emission controls. Its purpose is to reduce oxides of nitrogen (NOX) pollution in the exhaust. It does this by "leaking" (recirculating) small amounts of exhaust into the intake manifold through the EGR valve. Though the gases are hot, they actually have a cooling effect on combustion temperatures by diluting the air/fuel mixture slightly. Lowering the combustion temperature reduces the formation of NOX as well as the octane requirements of the engine.
If the EGR valve is not opening, either because the valve itself is defective or because its vacuum supply is blocked (loose, plugged or misrouted vacuum hose connections, or a defective vacuum control valve or solenoid), the cooling effect is lost. The result will be higher combustion temperatures under load and an increased chance of detonation.
Food for thought...
There is another link here http://www.streetrodstuff.com/Articles/Engine/Detonation/index.php
that is very good reading and even educated myself! (not difficult :lol: )
really :lol:
Frank
mods you may want to move this not sure
Food for thought...
really :lol:
Frank
