is the fuel filter the silver pot under the bonnet near the abs ? easy to do ?
T tombola Guest Jun 11, 2004 #1 is the fuel filter the silver pot under the bonnet near the abs ? easy to do ?
M MarkTurbo Well-Known Member Jun 11, 2004 #2 Yes, and yes Although sometimes the fuel lines can be a bitch to come of the filter.
S si.c R Guest Jun 11, 2004 #3 its attached to the bulk head. Its silver and is clipped in. Its easy to spot but not so easy to change as the pipes connected to it are really short.
G geetee Active Member Jun 12, 2004 #4 also worth running the engine with the fuel pump fuse out until it stalls to get rid of the fuel pressure from the line... otherwise don't smoke whilst doing it. Cheers GeeTee 8)
