clutch mystery......
H
heydirtyboy
hi all,
i've installed a new clutch helix, cars been runnin fine, now giving the symptoms of a slippin clutch, i've blead the system which helped firm up the peddle - gearbox is fine, but its still givin the apearance of a slipping clutch.....
any help your be great thanks
stumo
do you have any play in the pedal ?
you need approx 1 inch of pedal movement before it goes hard (Oooer missus)
if you don't then it's like driving with your foot on the clutch (and go look in the sticky section on how to adjust the clutch pedal)
H
heydirtyboy
its like the clutch is not engagin or dis-engagin right - its been workin fine then all of a sudden stopped. i've bleed the system, adjusted the pedal but no such luck yet i'm hopin its somethin simple.
